SuperCharging a KLDE, worth it?
What SuperChargers are there available/compatible with the KLDE?
Whats the estimated cost?
How much Torque would I gain?
I hear Jeff Abram's old MX3 with the supercharger hit 300whp, what other modifications did he have besides the SC?
My goal would be to reach atleast 230hp/230ft torque to the wheels
Of course, this is with other mods besides the SC
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
yes its worth it for the sheer fun factor, but its not to easy with our tiny engine bays.
I believe a Eaton M45 will fit, not sure about the M90.
Does Jeff or anyone have pics of the 300hp supercharged MX3?DavidOS wrote:yes its worth it for the sheer fun factor, but its not to easy with our tiny engine bays.
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- solo_ryder
http://www.capa.com.au/prices_eaton.htm $2789solo_ryder wrote:I was too thinking about doind a supercharger setup...any idea of the price?
more info
http://www.automotive.eaton.com/product ... rs/M45.asp
http://www.mx6.com/forums/showthread.php?t=128337
Cheaper than a turbo by about $1000 and a quicker install (what I hear, more of a bolt-on)
I am pretty sure that on Ebay there might be some for a cheaper price
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- Kokiriwave
jeff's mx-3 hit 296 hp with a turbo setup, he ditched the supercharger and made his own turbo setup. I believe.
you could make a turbo system for under 1700 if your money goes a long way and you do all the work yourself.
I want MAZDASPEED!
MY WEBSITE:: http://kingmx.net
Under $1700 with intercooler, BOV, FMU, wastegate, turbo turbine, piping, downpipe, exhaust manifold ect? Everything used?Kokiriwave wrote:jeff's mx-3 hit 296 hp with a turbo setup, he ditched the supercharger and made his own turbo setup. I believe.
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- MX-3 Money
Well if you really wanna do a sc, you should talk with the mx-6 and probe guys since you have a de. Here are some links to a site that is selling a sc setup for the 6 and probe. Now they are a lot of money, but i'd get one. They also have a turbo setup.
http://www.precisionracingonline.com/HOME.html
http://pmoforums.com/index.php?sid=6fb8 ... 00f622dd76
Now the sc setup they have might not fit a mx-3 or you'd atleast have to get some slimline fans. You have to relocate the oil filter too. Sounds like a lot of work and money, but it'd be fu*kin cool.
1993 MX-3 GS 5 spd, KL-ZE swap, kl31 ecu, 110 amp alternator, Unorthodox Underdrive Pulley, SSautocrome headers, High flow cat, Pacesetter high flow cat-back, B&M shortshifter, Clear Sigs/Sides.
Yeah last I remember jeff only made about 220 whp on the engine when it was supercharged. The 296 whp pull he had was on 14 psi on a turbo kit.
Jeff also had an extra injector controller, intercooler setup, and MSD BTM.
Turbo is definately more efficient and makes more power. I made 270 whp on 8 psi. This summer I'm bumping up to 15 psi, I'll be sure to dyno.
Depending on how you play your cards, you could build a turbo kit for much cheaper than an sc kit. I know I did. But it does require being resourceful and knowing how to weld![Wink ;)](./images/smilies/icon_wink.gif)
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
- XxantwawnxX
what did u run your 14.23 on? cause i just had a ze and i ran a 14.4....or was it a 14.2...cant remember. although my car was gutted. although im alot closer to sea lv : P
![Image](http://members.cox.net/antwawnhayes/Mx3comavatar.jpg)
hey luis (lucky13) its a ze
.... kl31 stamps. Unless its the newer de from the millenia but im almost certain its a ze.
-hec
Yeah that 14.23 run was pretty bad considering what I have. It did trap 103 mph though. Most ZE's I see run 14.5 or so run much lower traps, around 95 mph. What this says is that the car is capable of better times, I just can't get traction, and I need to work on my launch skills.XxantwawnxX wrote:what did u run your 14.23 on? cause i just had a ze and i ran a 14.4....or was it a 14.2...cant remember. although my car was gutted. although im alot closer to sea lv : P
Anyhow it was done on a stock exhaust, with stock muffler, pushing 6 psi. I say it was in the 220 hp range. Its much faster now, and I have slicks next time around
But in any case, if you're considering boosting your mx, don't hesitate. It makes this car totally different, it's simply awesome.
Like I said before, if you play your cards right, you could do a setup for a reasonable price. And as for supercharger or turbo, I recommend a turbo unless you find a real good deal on a supercharger kit. I dont think it cost anymore for a turbo, and its less maintanence and seems to be more reliable.
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
