To get a bit more space to work in, can I simply lift the radiator out of its mounts and lean it back abit? Or do I risk braking something?
Thanks,
Paul
Quick question, Pushing radiator back? Is it ok?
- vozaday2000
i can't see anything wrong with it. just watch out for anything falling into your fan and make sure that when the engine is running it isn't rubbing against the rad. otherwise as long as the coolant is flowing down and out the hose (which it should since you are leaning it back) it should be good.
http://www.cardomain.com/memberpage/730367 - UPDATED!!!!!!!
'94 MX-3 GS KLZE, KL01 Cams, Fidanza Flywheel, Centerforce Dual Friction Clutch, WeaponR Ram Air, 2 1/4 exhaust, Nichi Neptune Rims, Toyo Proxy 45 Rubber.
