progress of my turbo 2.5 mx-3
- babyblueMX3
well boys and girls..some of new the project I started a while back. just wanted to post progress of the car.
The only thing I need to do so I can start the car is weld my bov on the intake piping, modified the downpipe and cross member.
If you want to know what parts are involved in all of this just click in my sig the link to my cardomain page..It's all there
The car should be on the road next week end..can't wait to take it for a spin...after the break in..
RIP 400whp ZE-T MX-3
- atlantamx3
Thanks babyblue I gotta go clean my keyboard off now!!!!
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- babyblueMX3
yeah I already got the wrap..everything will be taken care of.atlantamx3 wrote:I sure do hope you heat wrap some of the stuff on the exhaust side of the Turbo.. its going to get hot 7 start melting stuff close to it... disty, radiator hose, etc.
oh and I'm working on a distyless set-up(coil packs) and no vaf . That's the beauty of megasquirt..
First off, I'm using stock injectors and 5psi for the break in, then I'm swapping 550cc injectors, megasquirt, wideband, remove the vaf, add water injection (already got the plug in in my megasquirt) and turn the boost up
ROFLMnemonic wrote:Thanks babyblue I gotta go clean my keyboard off now!!!!
hey baby have you made yourself an aluminum head sheild yet??? thats something ive been hunting down myself, to sit between the rad and distributor and the turbo. And i found some tough heat resistant metal. IF you look at your old k8 motor take the timing belt cover off and behind the pulleys is a black peice of aluminum that is flexible and would most likly resist heat well as it sits against the engine all its life. You can pull that off as its bendable and try to make that work.
- babyblueMX3
I actually got some spare ones here..I'll take a look at itDavidOS wrote:hey baby have you made yourself an aluminum head sheild yet??? thats something ive been hunting down myself, to sit between the rad and distributor and the turbo. And i found some tough heat resistant metal. IF you look at your old k8 motor take the timing belt cover off and behind the pulleys is a black peice of aluminum that is flexible and would most likly resist heat well as it sits against the engine all its life. You can pull that off as its bendable and try to make that work.
- babyblueMX3
- papa roached
i hate you man, i so hate you
- babyblueMX3
make sure you have to spark option with it..I don't think you can remove the vaf with only the fuel option.
anyways mine is still there because I'm using the stock ecu for the break in period then switching to MS that is wainting on my desk
so hows this all going?
- babyblueMX3
I tried to start it last night, it cranks but it doesn't start..turns out I don't have spark, I made another thread about that. I can't find the problem yet..I got everthing else though..just no spark
