Axles
Axles
Hey guys i am in the process of ordering the klze for my car. i wanted to know how much success anyone has had with leaving the stock axles in and if they did snap the axles where is the best place to get some upgraded axles that will fit the mx3. If anyone has any information let me know thanks guys. I was also wondering where i can get a good stage 2 clutch kit for the klze motor because i would like to replace that also. Thanks.
- vozaday2000
I can't help you with axles but people seem to really like the act stage 2 clutch. I personally like the centerforce dual friction and i found it cheaper than the act. it was about 320 CDN.
http://www.cardomain.com/memberpage/730367 - UPDATED!!!!!!!
'94 MX-3 GS KLZE, KL01 Cams, Fidanza Flywheel, Centerforce Dual Friction Clutch, WeaponR Ram Air, 2 1/4 exhaust, Nichi Neptune Rims, Toyo Proxy 45 Rubber.
![Image](http://memimage.cardomain.net/member_images/10/web/730000-730999/730367_31.jpg)
I havent had a problem with stock axles and I have a KLDE turbo. You should be fine.
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
Just get some axles with a lifetime warranty. The clutch masters stage 3 is a real good clutch and if you got the extra money get the fidanza flywheel with it to off of http://www.rr-racing.com
