RS Mani on a B6T
- TEAMpK
RS Mani on a B6T
Has anyone ever swapped their DOHC Intake Mani on to a DOHC B6T? I need to use my intanke mani to keep the sleeper IC setup I have. Thanks...
- Josh
if i remember correctly, the exhaust mani will fit but the intake will not. their has got to be a way to get it in there without cutting the hood. i know allot of diesels use flat intercooler piping. if you could rig something like that up, if you went wide enough it wouldn’t hurt flow too much. you could always customize one. I personally would use the BPT intake mani and cut and manufacture a new flange and have someone weld it.
You mean like this? This is a M1 Miata Intake manifold that we modified to work on the B6T head. The neck was cut off and we fabed up a custom plate for a BBK Mustang 75mm Throttle body. The other mod needed is a hold drilled in the diver side of the flange w/ a pipe adapter for the heater hose.
i was told the sohc intake mani will bolt up... plus if you do that you can upgrade to a larger tb
ProjectMx
My BP and AWD build thread
Cardomain
93 Mx-3 GS with bp and GTR AWD system
93 Escort GT daily driving
Cardomain
I've got my old SOHC motor in a deep dark hole. If I remember correctly, it doesn't fit. But if necessary I could dig it out.
nice
those are some nice custom parts there jw, maybe you could hook me up with the guys that did it.
http://www.cardomain.com/ride/1404826
BROKE DOWN POS
BROKE DOWN POS
i know
i know cause i helped him do it i was just messin with him!
BROKE DOWN POS
BROKE DOWN POS
