Been sifting through old posts, and it seems a little split on the consensus. does putting in a bypass valve really negate any gains from a CAI? To look at it, it doesn't seem very restrictive.
what do you say, experts?
do AEM bypass valves kill performance?
- XxantwawnxX
and u cant eve feel that.
![Image](http://members.cox.net/antwawnhayes/Mx3comavatar.jpg)
