NEED THE STEREO CIRCUIT DIAGRAM
When i bought my mx-3 it didnt come with a manual. now im taking out the stock head unit and putting in an alpine unit. the only problem is the wiring is different obviously and i dont know which wires are which from the stock wiring unit. i need the digram if someone could post or pm it for me but not in pdf format cause my comp can't read it. thanks a lot
~|\/|@$+|2O~
I can only print it to hard copy or pdf. You can't download Adobe Reader from http://www.adobe.com? Then you can download the diagram from my site below.
Alternatively I can fax it if you send me a fax number or can list the wire colours here. Let me know if this helps.
