steering wheel help!!
- misfitsfiend
iwant to install a steering wheel i got off ebay can anyone help me out ?
- Sam Baker
you're gonna need a spacer.. but to install it just unscrew the 3 screws on the back of the stock wheel, pop off the front part, and then remove the 21mm (size right?) bolt in the middle. if you have an airbag i've heard you might wanna unhook the battery before unplugging it. but yea simple as that really. the spacer will probably be needed to bring it out further so it doesnt hit the turn signals.. or at least that happened to me
92 Autozam AZ3
- misfitsfiend
- freyguy_412
