What kinds of bolt on and add ons can you get for the 94' RS
I have been talking w/ Jon(Trickmx-3) via email for a while now, because he's in my area. I am going to do anything to help him out. Just remember that he is real young and new to cars. My advice to you Jon is first get that car runnin right and maybe clean it all up a bit. Once I get a chance to get to your house, i'll try to give you more advice based on what i've seen
Where
Where can you get a cold air intake for the DOHC cause all i can find is for the SOHC if anyone knows anything let me know. Also i need to find a good pair of rear struts if you know where to get a cheap set let me know alright thanks.
- monty73741
Re: Where
the sohc intake will fit on the dohc
Jason Danaher
Please Help Support MX-3.com
why in hell would you use turbo cams in a NA engine.
my cardomain site: http://www.cardomain.com/memberpage/793483
my bad.... again... 0 for 2 in this thread. (quit while I'm behind )
- freyguy_412
I would only use the B6T cams if you are going to eventually turbocharge the engine. For a n/a car, I would just run the B6ZE Miata cams. There was a website on here someone posted that had a couple different sets with different lift and duration. They were only like $565 I think (same idea of swapping the ex for in and in for ex). When I do my head rebuild I'm gonna use those, and I'm probably going to use them with my turbo project too. Granted, it's gonna take me probably a year to get the funds to start these projects, but I will have a fast MX-3 someday.
It might be slow, but it's not a civic!
- Josh
i wasent really paying attention, the BP cams you can swap straight over. but as far as the 1.6 you need to run same lift and duration for both sides. its better that way anyways. it cost damb near the same to get custom cams out of blanks. iv been running the miata cams for several years now and in two different motors. and they help alot especially with the turbo. but you need adj. cam gears to get the timming perfect.
IT wouldent be good to run STOCK Miata cams in a MX-3 DOHC. because the duration is different from intake to exaust. intake is 236 and exhaust is 248. and you want more air leaving the motor than you bring in. so its best to get matching lift and duration for bothe sides. this is where i got mine http://www.integralcams.com/miata.htm
- freyguy_412
Josh said,
Hey yeah! Thats the site that had the cams for $565.... er... I mean $575!!!this is where i got mine http://www.integralcams.com/miata.htm
- Josh
yah i got mine and they were only 500 even. price is still really good. most places want more for just as good of a product. i wanted the toda racing cams but couldent justify 800 or so bucks.
