Right vicinty but rad hose in the way. Need to see base area of coolant filler neck. BTW, thanks M8.snellgrove wrote:http://www.snellgrove.co.uk/stuff/pictu ... 200055.jpg
Cooling fan starts after 2 min
- jschrauwen
- papa roached
even at this size its hard to miss the sensor
- jschrauwen
Chopperpozz
the back is your temp thermosensor, don;t mess with thatl.. its reads the temp of the motor in a .01 to .5 volt range. mess with that and your car will run like s---.. like if your coolant is low and that sensor is not submerched it will read 0 and ecu's don;t like zero!
93 Black KL-DE powered Mx-3.
E-mail - chopperpozz@hotmail.com
so your saying swapping out the neck for the k8 one is a bad idea chopper??? cause its should be a basic swapover.
Chopperpozz
no its ok to swap necks.. pain in the but tho,, i just tapped mine took all of 5min to do.
tapped yours, so you grabbed the sensor from the k8 grabbed a drill bit and tapped a hole in the coolant neck and shoved the sensor in then just plugged it into the ZE wiring harness? or where abouts did you wire it to?
