this is a repost, i posted a link to the terminator focus, the one with the full powertrain, drivetrain and suspension from a SVT Cobra under it
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
