if i want to replace my clutch what is all the stuff i need to purchase??
or should i just get one of those 'clutch kits' ??
any info would be great.
thanks
clutch
- freyguy_412
If I can remember some of my research correctly, the oem clutch is a little more expensive than an upgrade (at least here in the states). I will try to find the company for sure, but I think it is ACT that made a clutch. It might be a little better to replace the stock clutch with the aftermarket if it will end up cheaper.
It might be slow, but it's not a civic!
