new o2 sensors and still stalling
- ovendenk
hey guys,
to start, thanks for the help with my previous thread.
for the last 10 days or so my car stalls whenever the rpm's go below 800, ie. whenever it idles after warming up. i pulled the codes and got a code 24 (right bank o2 inversion error). after running the dianostic procedure, i found out that it was a faulty o2 sensor. i've now replaced both o2 sensors and my car is STILL stalling in the same f**king way. there are no more codes that are being displayed. does anyone have any ideas? fuel pump or injectors? ICS? i'm running out of ideas.
it drives beautifully, i just have to make sure that the rpm's don't drop below 1000.
thanks guys,
thanks guys,
kevin (aka The Oven)
93 mx-3 GS KL-ZE with KL31 cams and properly chipped ecu
All mods are on my website: http://ca.geocities.com/ovendenk
MX-3.com Worklog: http://www.mx-3.com/phpbb2/viewtopic.php?t=48462
![Image](http://ca.geocities.com/ovendenk/pics/Other/sig.jpg)
- XxantwawnxX
Vacum leak maybe?
![Image](http://members.cox.net/antwawnhayes/Mx3comavatar.jpg)
doubt its your TPS...
the tps is on the side of the throttlebody, u undo two screws & turn it til the proper voltage is being output.
Might be a vac leak. Did you reset the ECU after replacing the o2's?
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- ovendenk
that's funny because i found a a crack in the air intake tubing when i was leaving work today and taped it up in an attempt to solve the problem and ... voila! she now works wonderfully again. i just got home and saw your messages.
and i figured that the o2 sensors wouldn't affect it, but the code appeared at the same time. i guess it was just a wierd coincidence. thanks again guys.
coolant temp sensor? It starts to adjust the fuel when the car is warm but won't affect the way it drives until the car is fully warm.
but once warm, if the CTS is fux0red it can cause the car to run like crap, stall, and sound like a dirt bike. They are 18 bux new from autozone and easy to replace.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
