K8 ECU location
K8 ECU location
I am looking for the ECU on a stock mx-3 GS 1994 i cant find out where its at?
1994 Mazda MX-3 KL-ZE
crap....
well i see a few different boxes its it like where my petals are or like where the cd player is? (a pic would be nice if can be found)
- XxantwawnxX
Hope im not to late. i ran out and made a vid for u. Although it was night time i used a flash light to show u where the ecu is located.
http://members.cox.net/antwawnhayes/ecufinder.mpg
ECU
I am wondering is becuase i am looking in replaceing it. If i replace it do i just unplug it and plug a new one in for is there more i need to do?
- XxantwawnxX
If u replace..all u do is swap them yes. un bolt and un plug. but i doubt ur ecu is bad... unless u plan un putting a modded on in..or a ZE one (for future ze motor of course)
ecu
At the moment i am get my rims and tires and suspention done before i go to the eng so would it be ok to run a ZE ECU on a K8?
That's the new million dollar question
...seems like they're a few leads. Pray, they turn out good.
MX-3 Owners Club of Atlanta
Clemson Sports Car Club #72
MOCA tuned straight-neck KL-ZE '93 MX-3 GS : Updated: 03/05/06
- XxantwawnxX
I know cork sport has CORK SPORT/E.L.P. KL-ZE ECU Upgrade (ZE, V6) for if u have the ze.
