just as the topic name says... my car wont start...
the heater still works for some reason so i dont think its the battery.... but im not too sure cuz while i was driving whenever i hit the brakes even a little and rode the clutch to make turns and s--- .. my car radio would turn off ...
car wont start?
- misfitsfiend
- PWRD_BY_HKS
thats probably glitches in your computer
jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
- babyblueMX3
give us more detail...You can't expect us to help you out when the only thing you tell us is it won't start...
does it turn over...if not does it make any sounds like a clicking sound..did you try to recharge your battery..etc...
RIP 400whp ZE-T MX-3
