http://cgi.ebay.com/ebaymotors/ws/eBayI ... 7945582199
Woot Woot!
Look at all the stuff they replaced during the process!
Those who know the troubles I went through on my current BP.. although its in and running now-- who knows how long it will last.This is an ITEC Remanufactured Engine. The remanufacturing process included blocks fully cleaned, machined, and tested and assembled w/remanufactured crankshaft & connecting rods, new or remanufactured camshaft, new rod and main bearings, new pistons and rings, new freeze plugs, new seals, new timing chain/belt, remanufactured cylinder head(s), new or remanufactured valve train parts, new lifters (most applications), new oil pump (where available), installation gaskets (most applications).
This is some good insurance... basically an engine with ZERO miles for $300! I will just leave my current BP in for now until it decides to die, and then put the new one in!
