ze
- papa roached
cyborg zero is good for rods and pistons, mike seili on probe talk makes nice cams and teh ZE heads have bigger intake ports than DE heads
Re: ze
Noncmx3 wrote: Are the heads on the ze and de the same except for the pistons?
I dont want to steal this thread but what are the parts on the ZE that arent good for a turbo?
I think someone said camshaft. Dont remember.
Anyone know?
Anyone know?
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- papa roached
the higher compression pistons and if your going for big power the connecting rods
I'd replace the rods before the pistons. The pistons would still be good to round 7 pounds of boost. But out of the three engines I've pulled parts from to complete my rebuild, there were three bent rods. The rods suck a--. Wish I had the money for some better than stock rods while I've already got it torn apart.papa roached wrote:the higher compression pistons and if your going for big power the connecting rods
