Needed Help on Turbo BP Setup
- BuGS
Ok I have tried other places and no one seems to know. My target is 225 whp and around 200 lbs tq
I have an or am getting for sure:
VJ-20 w/ BPT Turbo Manifold
Corksport Downpipe w/ 2.5" Straight Back to CS Stainless Muffler
Greddy Emanage w/ PC support Tool
3rd Gen RX-7 Fuel Pump
3rd Gen RX-7 BOV (Am positive I will be getting a different one)
All Oil & Coolant Fittings
Huge FMIC (Like 30" X 6" X 3" core)
Spec Stage 3 clutch
Home Depot DBB Boost Controller
Now for the Questions:
-I need to Know if anyone has used an Emanage?
-Should I get RX-7 N/A 460cc injectors or Turbo II 550cc? (I think I can control both using the Emanage)
-What Size IC piping?
-Do I need a FMU or FPR? As long as I have the Emanage with the injector control will I need it??
-What Gauges do I get? I am going to be getting the 3 Pod (cause I have Auto Seatbelts) so I was thinking Boost, A/F, and ???
-Is there anything I am missing?
Thank you for your help!
Spec Stage 3 clutch
- Josh
Re: Needed Help on Turbo BP Setup
-you might have to have a shop do the Emanage. if you get it working properly it will be way better than the apexi AFC.BuGS wrote:Ok I have tried other places and no one seems to know. My target is 225 whp and around 200 lbs tq
Spec Stage 3 clutch
-i would go with the 460 their kinda too big as it is for the setup
-use 2" to 2 1/4" pipign if you go too big you will get more lag the quicker the spool the better
-the fuel presure regulator should work just fine.
-you should get an EGT gauge, kinda expensive but well worth it
-i think you pretty much gor everything covered. you will probably be making somewhere around what you want pretty easy. espically if you get the Emanage working good.
If you are using the VJ20, don't bother with the huge injectors, try to get something smaller. Larger injectors, especially the ones from the RX7don't handle lower idle pulsewidths very well and trying to tune your car for driveability and gas mileage with the smaller VJ20 will be a pain with the 440s+.
I would personally start out right with a proper wideband air/fuel gauge over the EGT. The EGT gauges can be hard to read, misleading at times (why did my motor blow, my egts are only bla bla bla), and slower to react. I can bet that nearly all dyno shops when they bring in a car will tune with wbo2, and will not try tuning on EGTs alone. I would not buy a cheap autometer attach to your stock o2 narrowband o2 gauge to tune a turbo set up with. The wbo2s are expensive although they are getting cheaper and price will depend on the options that you want with it. AEM UEGO and Dynojet WBC are two of the gauge-style wbo2s. The Dynojet has the ability to datalog directly to software, whereas the AEM does not. Beyond the ones that resemble normal gauges, there are again, many options.
A proper FPR (not rising rate) allows another way to fine tune a/f... I personally think they are worth while when you are working with stock ECUs and trying to tune around them.
- BuGS
-Well I was thinking of getting a A/F with the Wideband... But do I really need a FPR? Or will the MX-3 Or Protege one be good enough? I would think that it would.
- And unless someone have some like 370cc injectors they want to sell me for $35 I think I will go witht he RX7 460 ones. according to the emanage paperwork I can use the 550s easy. They can control Injectors up to 150% bigger (stock ones are like 230cc so thats 575cc?). The GTX 330cc would be maxed out all the time so I don't want to run those.
-I will also have a shop either in Seattle or Portland Tune the emanage. It matters if I can get my exhaust and parts from Corksport picked up by my brother if his car is still there...
- And Has anyone had any actual expeirence with a Turbo BP witht he VJ-20 that they want to throw some pointers to me? Thanks!
- Josh
dude thoes 330cc will work just fine. they are plenty of fuel. with that Emanage you can make your injectors turn out more fuel as well as less.
and your brothers car is still down there. that sux. that would be like 8 or so months now rite
it's the design of hte injectors from the rx-7 I don't like. don't handle low pulse-widths, high frequencies, or extreme pressures very well. Spray pattern, atomization suffer and the injectors go static too easy. Emanage doesn't care 100% about your driveability and gas mileage. I tested many injectors at the ol tuning shop in our injector lab, I'm just not a fan of the rx-7 injectors (similar to what RC engineering has, smaller scale). My turbo BP will not be running them. I don't recall what the BPT I tuned in the summer was running for injectors. He wasn't happy with his gas mileage whatever they were, although that was probably his heavy right foot.BuGS wrote:-Well I was thinking of getting a A/F with the Wideband... But do I really need a FPR? Or will the MX-3 Or Protege one be good enough? I would think that it would.
The FPR adds another area to tuning on any turbocharged vehicle... not neccessary, but more control is nice.
also, with using the itty bitty vj20, a 3" i/c is a little big. it doesn't flow enough to use up the i/c completely which could affect the effeciency of your setup.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
- BuGS
Well Someone Said that the 330cc won't last too long if I was to get those because it wouldn't be good to be running at 100% for long periods....Josh wrote:dude thoes 330cc will work just fine. they are plenty of fuel. with that Emanage you can make your injectors turn out more fuel as well as less.
But If anyone knows where I can get some 330cc ones or somthing please help.
- jaydog5678
- BuGS
BTW
I am currently getting enough Money to get
-370CC injectors (thanks Shady)
-Turbo XS H-RFL (Frikken Loud BOV)
-Emanage Ignition Control harness
-2" or 2 1/4" IC piping (right now 2 1/4" is cheaper
-EGT (cheaper than A/F setup), Boost (cause I need it), and Water Temperature (because I am haveing a huge FMIC and the turbo is coolant cooled)
Any comments?
THANKS!
![Confused :?](./images/smilies/icon_confused.gif)
Any comments?
THANKS!
- jaydog5678
again, egt sucks to tune with.... a/f first, even if it is more costly. The AEM uego and innovative LM1 are some cheap pre-built options and worth it. I've used many different types of wbo2, and I haven't come accross one that was so out of whack I wouldn't reccomend it.
Seeing as half the guys on here have never tuned a car, if you'd like to know my credentials, pm.
