buying a klze, got a ?
MX3parkerGS
Post by MX3parkerGS »
hey, im planning on buying a KLZE hopefully in about 3months for my 93 gs, and im trying to get prepared to know everything else ill need, like my CM clutch kit, and i read these forums and i keep seeing things like the ZE ECU and VAF, now when i order my ZE, will it come with a ZE ECU and VAF or? ive read u can use the K08 ECU and VAF but it doesnt perform as well is that correct?, but again id really like to know if when i order my ZE will it come with a ZE ECU and VAF or will i have to get those seperate?
THANKS IN ADVANCE!!!
Talon_66
Post by Talon_66 »
Our current VAF is the one u need.
As for ECU it really depends on the company, u purchase your engine from.
93 GS, KLZE, KL31 ECU, Centerforce Stg 3 Clutch, 2.25" Exhaust w/Flowmaster muffler, OBX Headers, Pheno Spacers, Front & rear X-drilled/slotted Rotors, KVR pads, SS brake & clutch lines, Ractive Filter, H&R Springs, Tokico Blue Struts, 8mm Accel Wires, MSD 6A w/ Blaster 2 Coil, HVAC Indiglo Panel. *Sold*
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
MX3parkerGS
oh, so the K08 ECU will work on the ZE? but the ZE ECU performs better?
'94 White MX-3 GS. Engine bay empty and waiting for the 2.5DE.
Completly stock, at this time.
Parker
papa roached
Post by papa roached »
if you run the K8 ECU and VAF it will run super rich, get a KL-DE VAF and run that and the K8 ECU or get a KL-ZE ECU and run it with the K8 VAF
MX3parkerGS
DOes anyone know which combo is best to use for performance?
Parker
IanL
Post by IanL »
For best results use the ECU and the VAF designed for the engine - that's a KLZE ECU and the VAF on your K8. This information has been posted countless times, as well as a whole lot more. Do some reading up.
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system :)
