ignition wiring
ignition wiring
My MX-3 1.5 auto came with a non standard immobiliser which stopped working and immobilised the car. I've removed the immobiliser but am not sure on the wiring. The car still won't start (is totally dead) can anyone help please, maybe with a wiring diagram for the ignition?
- Typhoonk
follow the wires from the immobilizer. They should go to a factory wire that has been cut.
Then you just remove the aftermarket wiring and rejoin the factory wiring.
Most immobilizers are starter kills. So I'd look at the ignition harness around the steering column. Remove all the plastic around the steering column, and the plastic panels below that.
PM for info
PM for info
