Turn signals have a mind of their own
Franko
Post by Franko »
I have a friend with a 93 gs and whenever she turns the wheel left or right the turn signal for whatever direction you turn comes on. You dont have to turn it very much to get it to happen but it always happens. I took the cover off to try and see what is going on under there and it makes very little sense why its happening. Anyone else ever have this problem?
Sam Baker
Re: Turn signals have a mind of their own
Post by Sam Baker »
i had a 71 vw super beetle that whenever i turned the wheel the horn would go off... :freak: it was possessed!!! but nah it's prolly just a caught connection somewhere inside. just take the wheel apart and have a look
92 Autozam AZ3
MX3-Freak
Post by MX3-Freak »
I would suspect it is "catching" when the wheel turns and should not be doing anything to the signal under normal operational conditions. But in your case, the mechanism that "auto-offs" the signal after completeing the turn decided to have its own opposite day/week/year/eternity :werd: . That would be my best guess. Good Luck.
<small>[ August 31, 2004, 09:50 AM: Message edited by: MX3-Freak ]</small>
Stock 1995 RS - Creek Blue
Car Meanins:
Vanished
Post by Vanished »
Yah, just take ur wheel apart. I figured out how the signal lights turn on and off, its a little mechanisme. Check it out, its probably catching or something.
1992 Blaze MX-3 GS *R.I.P.*
1993 Blue 93 SE-ZE
http://www.cardomain.com/ride/2770987/2
