turn and hazards gave out...relay?
MOSES
Post by MOSES »
last night, i was driving down town, when i put my signal lights on the came on and satyed on, then when i tryed my hazards, all four lights came on, so i turned them all off and left it.
would this be a relay?? where is this relay?
all the turn lights work, none are blown, its almost like the relay is stuck.
thanks all
I've been so unsatisfied with my car since I joined mx3.com.
Seeing all the body kits, rims and engine swaps makes me want to spend all my student loans on my car.
Grants
BANNED Member
Re: turn and hazards gave out...relay?
Post by Grants »
Sounds like the flasher unit which is mounted under the drivers side dash. Its a grey box with a white plug in the bottom with 6 wire going to it.
That would seem the best place to start.
