Fog lights for Mazdaspeed style bumper, recommendations
Andrew_Pakula
Post by Andrew_Pakula »
Can anyone recommend any good fog lights that will fit and look good on the Mazdaspeed style bumper in the two corners? I have seen a few mazdaspeed style bumpers with various different fog lights but I am not sure what to get.
Basically overall i want a clean look, bigger doesn't mean better, I don't want a rally sort of look with big round lights.
Right now I am just looking for ideas because I will be getting something before spring.
ryanlindenberg
Re: Fog lights for Mazdaspeed style bumper, recommendations
Post by ryanlindenberg »
i used some cheap APC "projectors". they have an 7-color LED ring around them too which i rarely use. they take awhile to install because you have to make some custom brackets. the wiring also takes awhile. there is a pic on my cardomain...page 3 i think.
CARDOMAIN WITH UPDATED PICS
Custommx3
Site Administrator
Post by Custommx3 »
I used a flat plate.. drileld 2 holes in it close to the edge.
Then, I mounted the lights to the plate.
Aligned the plate where I wanted it, and drilled out the bumper using the holes as guides.
Heres a pic of it, you can kinda see. Its high res, so u can see it better.
http://www.barrykclark.com/pix/101103.JPG
<small>[ January 19, 2004, 03:46 PM: Message edited by: Custommx3 ]</small>
Taras
Post by Taras »
Do you want the fog lights that will look good or the ones that will work good. Do you drive in a lot of fog?
Taras
'92 GS Gray ZE
'05 Gixxer 750
MxWest VP
www.mx-west.com
