ebay altezzas
Jon_Carnie
ebay altezzas
i was wondering if any of the people who have bought there altezzas off ebay have had any troubles with them leaking, i bought mine off of ebay a while ago and the right side leaks, and i have tried resealing it twice and it didn't work either time, i was thinkin about just buying another set off ebay, but don't want to if they are just going to give me more trouble, any imput?
Mnemonic
Re: ebay altezzas
buy you a new set them have them clear coated that will seal up any leaks
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- atlantamx3
Re: ebay altezzas
What?? Brian?? Are you smoking crack again?? LOL.Originally posted by Mnemonic:
NO, Jon-- You may have missed a connection point when you were sealing them. I think there are 6 for each light. They are little tabs. Put some RTV (I think) sealant on each one, and be sure that it covers the whole area. Its water tight and weather-proof.
I have had mine sealed now for many months-- with no problems!
Jon_Carnie
Re: ebay altezzas
so just seal around the tabs? alright sounds good, i'll give it a try, thanks alot
MikeUK
Re: ebay altezzas
I had the same problem with mine, strangeley enough on the right had side too. So I took them off and put them in a warm place until the water had evaporated. I then sealed the 6 points on top of the lights with clear silicon. And put them on again. Only to have them leak again. I then took them off again and relised I also had to seal along the top front of them. Its a small gap which lets in water all the time. I put them on again in the dark while it was cold. And oh yes managed to crack the one on the righthand side.
GUTTED. So im ordering a black set now which im going to take my time on.
Re: ebay altezzas
mine did the same from pakfiefer
check my car domain
http://www.cardomain.com/ride/2144443
Re: ebay altezzas
Got mine from EBAY.. (fusionmotorsports)
Have not had a single issue with them..
Sounds like it is hit and miss..
Jon_Carnie
Re: ebay altezzas
yea it really does seem to be hit and miss, but from what i've heard its mostly the right hand side that leaks, i guess i'll take my chances with another set, and seal those 6 tabs on them before i put them on the car...
- millionflame
Re: ebay altezzas
I have one of the first ones made by Pakfeifer, from the first group buy done by Oscar.
Mine didn't leak until just recently, so that means they've lasted about one year and a couple months before they started to leak.
First it was the passenger side, then the driver's side a few weeks later.
I just took the lenses off and re-sealed them properly. More to the point of over-sealing to make sure. No problems now.
~ Millionflame (94 GS 120K)
