klze transmission swap
A forum for discussions regarding the MX-3' transmission. Swap, technical, and troubleshooting info should be placed here.
richocet1
Post by richocet1 »
Is it possible to swap a KLZE transmission into a 1.8 GS without swapping engines or only swapping a kfze? I found both really cheap and need to do the swap. I burnt out my transmission and possibly siezed my engine.
You still can't touch my car!!!
Sonicxtacy02
Re: klze transmission swap
Post by Sonicxtacy02 »
yes. The transmissions are all the same with the exception of the j-spec LSD.
Shaun Newman
Return to “Transmissions”
