ATX 2.5
A forum for discussions regarding the MX-3' transmission. Swap, technical, and troubleshooting info should be placed here.
Show_MX
ATX 2.5
Post by Show_MX »
For all the engine gurus in here, my problem is this. From a dead stop, I've been able to tear up a few civic's,teg's, even gave a gs-t a good run. The problem I'm having is higher RPM torque. It seems anything over 3500rpm the engine just revs high and doesn't really put anything worth mentioning to the road. Tranny is not slipping so the question I have is what internals can change this without having to do a 5-speed swap?<BR>Thanks for the help.
MAZDASPEED STEVE
Re: ATX 2.5
Post by MAZDASPEED STEVE »
sounds like your torque converter? :D
THANX
MAZDASPEED
STEVE
Return to “Transmissions”
