Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
Mods:
- ZE, Mike seli 214 intake cams, Ported n polished heads, Interprep valve springs, DE retainers, rebuilt bottom end, toga main and rod bearings, toga hv oil pump, CZT 67mm tb, mbx udp, ported intake mani, SS headers, 2.5inch full exhaust, racingbeat muffler, highflow cat, megasquirt v2.
new toy, 86 TII rx7, JDM S5 motor/turbo, + alot of other goodies
