Big brakes?
mdavis
Big brakes?
Post by mdavis »
Does anybody make a big brake kit for the MX3? Thx.
GS-R SE
Fixin's
papa roached
Re: Big brakes?
Post by papa roached »
check corksport, they carry one, the only one i have ever seen and i hope ya got deep pockets
nope-mx3
Re: Big brakes?
Post by nope-mx3 »
www.precisionbrakes.com has some bigbrake kits.
Both front and rear.
nope-mx3
:: 2001 Mazda Mx-5 Sport // 2013 Volvo V40 D2 Momentum ::
fry_81
Re: Big brakes?
Post by fry_81 »
do their calipers work on the oem rotors?
1994 5spd GS Parts Car For Sale 800obo. e-mail for details. fry_81@hotmail.com
jaydog5678
Re: Big brakes?
Post by jaydog5678 »
No.
Gro Harlem
Re: Big brakes?
Post by Gro Harlem »
if you custom make your own brackets, its not too difficult to adapt 4-piston RX7 calipers & some 11" rotors to your car. I have the parts, but i'm waiting for my buddy to go home and cut me some brackets for the calipers. I'll see how it works out..hopefully it'll fit ok.
DONATE TO MX-3.COM
ProtegeSTS
Re: Big brakes?
Post by ProtegeSTS »
don't waste your money
-93 MR2
#129 E-stock
Gro Harlem
Re: Big brakes?
so far i've invested 80 dollars on brand new 11" rotors & two rx7 calis....i wouldn't say thats a waste of money :)
DONATE TO MX-3.COM
ProtegeSTS
Re: Big brakes?
i would. I could spend 80 and get 4 good pads for the oem calipers, and id have a working brake system, and you'd have a box of parts.
:p
-93 MR2
#129 E-stock
mdavis
Re: Big brakes?
Post by mdavis »
Am I missing something here? Are you just assuming Gro's project won't work or do you have experiance with this?
GS-R SE
Fixin's
papa roached
Re: Big brakes?
you might be able to do that and have a working braking system, but when gro is done with his he will be able to stop better than you, hands down
Gro Harlem
Re: Big brakes?
I already bought some performance pads.....the brakes still aren't performing to my satisfaction. I even got new front calipers and they still suck.
Hopefully these 4-pots will fit....rx7 cali's are pretty easy to source from junkyards & the rotors i'm using are actaully really inexpensive.
oh ya, i'm not gonna reveal any of the info on the rotors until i'm 100% sure they'l work. I don't want to piss ppl off and waste their money when i'm not even sure if they'll work.
DONATE TO MX-3.COM
The_Great_Tonge
Re: Big brakes?
Post by The_Great_Tonge »
protegests = teh bich!!
don't listen to anything that negative nancy has to say, good luck with your project gro!
mx3man83
Re: Big brakes?
Post by mx3man83 »
Protegests knows his stuff. He may seem like a chode sometimes but he knows his suspension/braking information. By the way, good luck on those brackets, hope they don't brake on ya.
My Cardomain site
papa roached
Re: Big brakes?
every big brake upgrade i have ever seen uses brackets to space off and bolt on the calipers, its a proven system
