I am debating whether I need a new rear sway bar if I already have a decent sized one now.
The pre 94s have a 19mm I beleive and would definately be better to go with the 22mm but how much of a difference is 1mm?
94+ mx-3 has 21mm rear sway bar?
"A hero and a coward both feel fear but it is the hero who reacts first while the coward hides behind the hero"
Re: 94+ mx-3 has 21mm rear sway bar?
I'm also debating if i want a whiteline bar. 22mm isnt much of a difference. Are there bigger bars? 25mm maybe? Alittle oversteer never hurt anyone
Mods:
- ZE, Mike seli 214 intake cams, Ported n polished heads, Interprep valve springs, DE retainers, rebuilt bottom end, toga main and rod bearings, toga hv oil pump, CZT 67mm tb, mbx udp, ported intake mani, SS headers, 2.5inch full exhaust, racingbeat muffler, highflow cat, megasquirt v2.
new toy, 86 TII rx7, JDM S5 motor/turbo, + alot of other goodies
25mm is way too big unless u upgrade the frt one.
If the frt one is 21mm then a 22mm in the rear is perfect but most guys on here have the 19mm rear bar which is why mazda upgraded the rear one in 1994.
I would rather have a urethane bushing kit.
Also I am wondring what year is nope-mx-3's car.
keep in mind that the stock one is possibly hollow...
also, sway bar stiffness is determined by the square of the diameter, so a small difference in diameter makes a big difference with the car.
-93 MR2
#129 E-stock
#129 E-stock
So lets say i somehow got a 25mm bar, what size is the mazda speed bar for the front? Would a 25mm bar in the rear and a mazda speed bar in the front be almost balanced with maybe alittle oversteer ?
Mods:
My car is a 92.Originally posted by nvrsrndr:
I believe we measured the original bar to be 20mm.
those 2-3mm had A LOT to say on the handling of the car. I almost didn`t recognise it.
nope-mx3
:: 2001 Mazda Mx-5 Sport // 2013 Volvo V40 D2 Momentum ::
The benefits in handling aren't just determined by how thick the bar is. The material the bar is made of, and whether its hollow/solid also have a lot to do with it.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
The stock bar is hollow. I have Masdaspeed one and the weight difference in bars is big. So is the handling. Too bad it adds weight, but more fun in the corners. I would be careful with adding too big of a bar, because it makes your suspension less independed, and your ride harsher. I know it is not a big deal to most of us, but too much harshness is not fun.
