i use the 2 gen protege mazdaspeed strut & kg/mm spring in my mx3,it
fits perfectly,just swap mx3 strut mount only.so we have more choice
for the spring & strut. i'll try the taiwan made true coilover later
92 yellow mtx klze presso,K&N cone filter,KLZE ecu & intake manifold,whiteline front & rear strut bar, apex spring,koni strut,whiteline camber bolt,WHITELINE rear 22mm swaybar,magnecor 8.5mm sparkwire,2.5" custom catback,custom testpipe,FSE fpr,sard oil gas tank,apexi S-AFC,15"RAYS TE37 rim,FALKEN ST-115 tire,EVO4 front brake,mazdaspeed seat,mazdaspeed steering wheel,mazdaspeed front nose
