Rear tie bar
Rear tie bar
Does anybody know where i can get a rear tie bar and a front tie bar thanks
Re: Rear tie bar
the GS model CAME with a rear lower tie bar from the factory. You could have any fab shop make you a lower front tie bar. If I remember and we get the chance...which wont happen anytime soon, I need to measure David's car to see of the OTLM front or rear bar will work on the MX-3s. I know the rear will, butim not sure of the front, because of the different engine.
-93 MR2
#129 E-stock
#129 E-stock
- Custommx3
- Site Administrator
Re: Rear tie bar
goto a junk yard, pull one off of a GS, prolly cost you 15 bucks if you pull it yourself, undo 1 side at a time, put the bolt back on, bring a jack. simple procedure, its 2 bolts on the rear axle. The on eon my RS came off of daniels old car.
Re: Rear tie bar
If you want you can also buy one at: <A HREF="http://www.srdperformance.com/" TARGET=_blank>http://www.srdperformance.com/</A>
Jean-François
Now Mazda MP3 2001 Owner
The MX-3 is sold !
The MX-3 is sold !
