rear disk swap
rear disk swap
does anyone know whats all involved in swapping the rear drums for disk brakes? i have to replace my drums anyway, i'd rather do the swap now since i have to spend the money.<P>thanks<BR>dave
ProtegeSTS
Re: rear disk swap
if you do a search, i think you'll find what youre looking for...but from what i can remember, you basically need all the rear pieces off a GS model.
-93 MR2
#129 E-stock
#129 E-stock
pelado
Re: rear disk swap
Check out the online shop manual. That should give you an idea of what you need. Better yet, go ask the parts person at a Ford/Mazda dealer. They should tell you what part numbers are the same, which are different.
Re: rear disk swap
I also read you need to change the master cylinder to the GS version because it is stronger.
