weapon-R witch ones?
what weapon-r coilovers will fit the mx-3 is it the ones for the 91-96 protege?<BR>also will these work well with the zx2 tokico<BR>strut??
"guess i forgot to put the foglights in"
Re: weapon-R witch ones?
Yes, and I believe so. You'd have to call them and ask the diameter of the collars, because I believe the ZX2 struts are a bit larger.
-93 MR2
#129 E-stock
#129 E-stock
would you happen to know the diameter of the zx2 struts?<P><BR> t.i.a
i have the weaponR coilovers and from personal experience, i strongy do NOT recommend them. the ride is worse than a school bus even with new struts. not the answer you're looking for, but i wish every day that i had spent the extra money on the ground control CO's. corksport will know which ones to buy if really wanna know.<P>dave
