t25
t25
would a dsm t25 turbo be a good size for the 2.5 ze??
to small?
to big??
to small?
to big??
- babyblueMX3
Re: t25
wich dsm engine did a t25 came out of...it thought they were all like td04h (or something like that)
oh you bet this turbo is too small
this is smaller than a t3 and the smallest 3t3 I've seen on the 2.5 was the t3 super 60 wich is a big t3
<small>[ November 07, 2004, 09:23 AM: Message edited by: babyblueMX3 ]</small>
RIP 400whp ZE-T MX-3
Re: t25
ok cool hey babyblue what are some good turbos to stick on a ZE??
T04?
or garret T28?
what do you plan on using. i have a friend who might be able to get cheap turbos.
T04?
or garret T28?
- babyblueMX3
Re: t25
i'd say get a t3 super 60 or any t3/t4 turbos..
t28 are also too small and t4 is good if you are planning on BIG boost but if not stick with the others..
I personnaly have a t3t4
- goldsberry1
Re: t25
actually if you do the math and then look at the flow chart of the t3 super 60 its too small too. our engines (2.5) needs about 31 lbs/hr at 6500rpm. look at the maps to see which ones right for us. i'm useing a t3/t4 with a .63 turbine and a .60 t4 compressor. i will be starting at about 6 psi.
92' mx-3 gsr, built engine, forged internals, p/p ze heads. t3/t4e .63/.60 turbo, udp, msd ignition, millenia s injectors, millenia im, water cooled intercooler, afpr, fmu. running at 7 psi right now
- babyblueMX3
Re: t25
well if you're running low boost it should do the job...some people on probetalk are using it
- mrspanky79
Re: t25
dos anyone have a flow chart for the t25 because i have yet to fined a real full chart.
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
99 vitara 4x4
- babyblueMX3
Re: t25
nope never saw a good one either but their's still this one ...
but this site says that a t25 is good for 210-250 bhp max
- mrspanky79
Re: t25
thats the best i can fined to. I want one with all the graphs and % on it
99 vitara 4x4
99 vitara 4x4
