What is the factory wastegate set at on the BPT?
Free reving in my driveway(I know this is bad) I'm getting pressures of 10+ on the boost gauge. I was under the impression that the factory seting was arroud 7psi not 10-13.
quick question
quick question
BPT SWAPED MX FOR SALE!!!
http://www.mx-3.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=007118
http://members.cardomain.com/ricerocket666
AIM: l3acardiRon151
AIM: l3acardiRon151
Re: quick question
now many rpm do you rev it to? i don't see how you can reach that high of boost w/o a load on the engine. the factory gate is about 8.5psi
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
- jaydog5678
Re: quick question
Also, how are you controlling your boost? Apexi, hks, haltech solenoid, etc..??
Re: quick question
I have no boost contoler. The wastegate is hooked directly to the intake tube. It as my impression that this should keep it at factory boost levels. I hit 10psi at about 5500. This wasn't sustained boost, I just floored it for a sec to see if the new BOV was working. I only had the pedal down for about 2secs tops.
AIM: l3acardiRon151
AIM: l3acardiRon151
- jaydog5678
Re: quick question
You'll need a boost controller, PERIOD!
I was able to bend 2 rods while spiking up to 20+psi. Those rods won't take that kind of abuse for long.
The line from your wastegate has to go to the electronic device or manual valve as a way of controlling boost. Running straight to your intake, the valve in the wastegate would never open, therefore you'll see alot of boost around 3000 rpm.
Re: quick question
the wastegate needs a boost reference. if you have a poor reference, then the wastegate will never see any pressure therefore it will not open. i was running my wastegate off the back of the intake manifold for a little bit and worked fine.
"MR." Ashley Fowler
cardomain pics
"MR." Ashley Fowler
cardomain pics
