haltech
mclaw-mclaren
haltech
Post by mclaw-mclaren »
If you have a S-AFC and get a Haltech is the S-AFC pretty much pointless?
thanks
~~McLaw~~
MX-3 -- BPT
Marlon
Re: haltech
Post by Marlon »
thanks
yep
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
mclaw-mclaren
Re: haltech
with a haltech, u don't need a Turbo timber and a Boost Controller, correct?
~~McLaw~~
MX-3 -- BPT
maldo
Re: haltech
Post by maldo »
Haltech's boost controller sucks, it works but sucks. Pick up an AVC-R or E01 boost controller, better all around.
mclaw-mclaren
Re: haltech
even with the new EGX, so it does have a turbo timber also?
thanks for the fast reply!!
~~McLaw~~
MX-3 -- BPT
maldo
Re: haltech
Post by maldo »
E6X
Still uses the same type of boost controller. Boost is controllable but not gear or speed selectable.
OsoSlo z28
Re: haltech
Post by OsoSlo z28 »
i agree. the haltech boost control function works, but it's tricky. unlike the other controllers out there(a'pex etc) you actually have to adjusts bars to get the solenoid to bleed off enough air to get your're desired boost level. the tricky part is that it varies throughout the rpm scale.
even if just for simplicity, go with something else for boost control.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
mclaw-mclaren
Re: haltech
k, but i don't need another turbo timer, Haltech is good enough?
thanks
~~McLaw~~
MX-3 -- BPT
OsoSlo z28
Re: haltech
i'd suggest getting a diff turbo timer as well, simply because in order to use the haltech for a turbo timer, you need other items(relay's, solenoids, etc.) if this is on a bpt, you don't really need a tt as the turbo is water cooled.
"MR." Ashley Fowler
cardomain pics
mx3optidrive
Re: haltech
Post by mx3optidrive »
mclaw-precidian:
do you have a s-afc and changing to the haltech? If you do have a s-afc, are you selling it and if you are how much do you want for it?
Shop 506-577-6708
cell 506-381-3503
email danny@jdracing.ca
mclaw-mclaren
Re: haltech
mx3optidrive - u have mail
~~McLaw~~
MX-3 -- BPT
Return to “Forced Induction”
