haltech
haltech
If you have a S-AFC and get a Haltech is the S-AFC pretty much pointless?
thanks
thanks
~~McLaw~~
MX-3 -- BPT
MX-3 -- BPT
Re: haltech
yepOriginally posted by mclaw-precidian:
thanks
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
Re: haltech
with a haltech, u don't need a Turbo timber and a Boost Controller, correct?
~~McLaw~~
MX-3 -- BPT
MX-3 -- BPT
Re: haltech
Haltech's boost controller sucks, it works but sucks. Pick up an AVC-R or E01 boost controller, better all around.
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
Re: haltech
even with the new EGX, so it does have a turbo timber also?
thanks for the fast reply!!
~~McLaw~~
MX-3 -- BPT
MX-3 -- BPT
Re: haltech
E6X
Still uses the same type of boost controller. Boost is controllable but not gear or speed selectable.
Chris Malden
MX-3 RSR
MX-3 RSR
Re: haltech
i agree. the haltech boost control function works, but it's tricky. unlike the other controllers out there(a'pex etc) you actually have to adjusts bars to get the solenoid to bleed off enough air to get your're desired boost level. the tricky part is that it varies throughout the rpm scale.
even if just for simplicity, go with something else for boost control.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
Re: haltech
k, but i don't need another turbo timer, Haltech is good enough?
thanks
thanks
~~McLaw~~
MX-3 -- BPT
MX-3 -- BPT
Re: haltech
i'd suggest getting a diff turbo timer as well, simply because in order to use the haltech for a turbo timer, you need other items(relay's, solenoids, etc.) if this is on a bpt, you don't really need a tt as the turbo is water cooled.
"MR." Ashley Fowler
cardomain pics
"MR." Ashley Fowler
cardomain pics
Re: haltech
mclaw-precidian:
do you have a s-afc and changing to the haltech? If you do have a s-afc, are you selling it and if you are how much do you want for it?
