Dodge Stealth turbos
I have a friend who might beable to get me two turbos off of a Dodge stealth would these fit onto my SOHC engine or would i have to put them onto my DOHC engine that i will be swapping in later?
14" 5 spoke PRIME rims, GS spoiler,180 Watt Sony Head unit with a 4 Polk Audio EX series speakers, Kicker Solo Baric 8" sub, StrandTec custom Air system, Blue under dash neon tube, Blue windsheld wipernozzle LEDS,straght-through dual tip exhaust, Belive it or not but, I did a 0-60 in 7.23 seconds!
http://www.cardomain.com/id/seanthemx3er
Re: Dodge Stealth turbos
are you looking to twin it? I only ask cause you said turbos. Either way i'd think those would be too big for your application.
Shaun Newman
well i would be able to get two but i was reading on here that they would put out too much boost so i was only going to go with one and maybe sell the other or keep it as a spare
I think that because the Dodge Stealth engine has a higher displacement they'll take longer to spool up on your RS. When they do, it may be too much boost for you to handle without careful management.
- ryanlindenberg
was the stealth a V6. if it was maybe each turbo was running off of 3 cyl. then the turbo wouldn't be very big...
CARDOMAIN WITH UPDATED PICS
a small turbo would be ok for me im not asking for too much boost not like my one of my friends whos running 47lbs of boost in his car, but anyways i know that i would need a manifold, intercooler, larger fuel pump, larger injectors, blow off valves, wastegate, umm is that all?
The way twin turbos work is by having a small turbo that spools quickly at low RPM and then it transitions to a large turbo that produces big power at higher RPM. You could potentially make either turbo work, but they would have different results. Also you may want to look into getting a piggyback fuel computer, or if you are really hard core a get a stand alone fuel computer.
'94 Blaze Red RS<P>I may not have a lot of horsepower but I know how to use it!
WAY too small to use as a single turbo on anything above 1000cc. Not bad for twins on a 2.5L
David Coleman
Aren't those 12g?<p>If so, they are the same use on 2.0l Eagle Talon and Eclipse. Why would they be to small for 1.6l application?
Manach
Ex Mx'er with a Mx-3 1993..
Still in the Mazda Familly with :
-Mazda Rx-7 1987 GXL (Not running, one housing does not compress)
-Mazda Protege MazdaSpeed 2003.5 Titanium!
Still got 3 Engines!
- B6-ZE : Turbo Festiva project (Waiting donor car)
- BP-DE : Trader for a B6-ZE 1994 for parts upgrade in the Festiva project
- K8 : For sell. Pm me for info!
Once you go turbo, you can never go back!
Would this work or not? Becase i also know where i can get some Stelth turbos but i have to pay for them
What did i do wrong? Oh yeah I bought a Honda
A simple search on google will tell you that they are 9B mitsu turbos, which are too small for using single on a B6. And twin turbo 4cylinders are stupid, unless they're boxer 4's.
David Coleman
Yup, I made a Mistake, 9B,<p>My friend almost killed me for me saying that
Manach
The 1st GEN Eclipses (4G63 turbo) used a single 14G...not a 12G. However the 2nd GEN Eclipses (4G63 turbo) used a Garrett T25. My friends are DSM nuts!!!
Ok, we got 2 informations..<p>Where can we clarify this? I mean.. a URL!
Manach
I did make one mistake....<p>The first Gen is a 14B not a 14G.
And I am right.<p>http://www.extrememotorsports.com/staged.htm<p>Check out the link.<p>My friends shop is called ET Motorsports
www.etmotorsports.com<p>
