zex
93mxrgs
zex
Post by 93mxrgs »
anyone running zex on thier mx-3... i just won an online auction on ebay, and just wonderin if anyone has this... the kit i got is for a mustang 4.6 5.0... but i figure it should work just fine for my mx-3 with the probe motor... then only question is the tps.. im pretty sure that our engine run like 4.5or 5 volts, and i need it to be at least 4.2 otherwise the nitrous wont kick in... anyone know this for SURE.. dun worry its not goin o till i find out absoluty,,, the kit comes with jets for 75-125... and yea i have an upgraded fuel pump. but im planning on buying a 55hp jet
Black-93 mx-3 Gs-R<BR>with goodies :) :)<BR>Hondas suck, and yes i race them...<BR>oops i mean no no i dont
Shady469
Re: zex
Post by Shady469 »
if i dont get my turbo im gettin zex. our cars run at 4.5 according to the peeps on the boards.(i also called zex and they said it would work) they just came out with a purge valve u might want to look into buying.<BR>and they make plugs for our car that work better with forced induction set ups which u might wanna get too.
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
Shady469
Re: zex
Post by Shady469 »
hey! i know this is a little late but check with ZEX!! there was a guy with a civic kit i was gonna buy but the middle man of the deal had the sence to call zex and it wont work on ours, somethin about us not having a feul return line or somethin. anyway the eclipse kit will work but i decided im just gonna by one new.
maldo
Re: zex
Post by maldo »
You were wrongly informed, there is a fuel return line. Take a look for yourself, two lines coming off the fuel rail. I have talked to ZEX about using a kit on my B6T, they suggested I use part #82011. They are nice kits as long as you aren't looking for more than a 75hp shot.
Shady469
Re: zex
Post by Shady469 »
yep i talked to Zex and the local Mazda Dealer and both said we have the return line. *JOY* so i bought a kit w/ warmer and full bottle for $425.i'm not puttin it on till i get my injectors/spark plugs and a new clutch though.
93mxrgs
Re: zex
Post by 93mxrgs »
you CAN run up to a 125 shot with zex. i got the mustang kit, but the only differnce in kits is the jets..., they;ve changed they;re tps system, where it will read ANY volt outage.... so it can be used on all cars.. kinda hard to explain but its in the directions :).... now i just gotta figure out where im gonna mount the solenoid box
Shady469
Re: zex
Post by Shady469 »
Arming the system: does anybody know can it be armed on the fly? cuz i don't wanna spray in first (traction) but WOT through the rest of the gears will do me fine.
93mxrgs
Re: zex
Post by 93mxrgs »
im talkin to a rep right now. and he says that he believe you can... but ima call the ZEX line so i can figure out for sure
Return to “Forced Induction”
