APEXI Super-AFC's Correct Sensor Settings
Re: APEXI Super-AFC's Correct Sensor Settings
I just bought one and I hope to first know what you guys are talking about (5 5, 7 7)and then learn how to put it in. How long does it take to wire in and did you do it yourself?
Yes you can, by using a map sensor to provide the voltage it would normally see from the TPS.<P> <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Tyranos The Great:<BR><STRONG>Ah, thats what I thought (wot only). Sucks. I wonder if its possible to somehow get a throttle position based voltage signal to the SAFC.... oh thanks for the fast reply! lol<P>Shikyi</STRONG><HR></BLOCKQUOTE>
93 EGT Turbo
a map sensor is the best thing to use, but will the ecu be able to read the input from it? how would you connect it so it would work?
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
the ecu would not have to read it. you can power it up on a seperate curcuit and make sure the output parameters are what u want and feed that signal to the super afc. you will get the signal you want in map sensor form without bringing the ecu into the picture. but... you have to make sure that the voltage that u are getting only go up to what the tps puts out at wot. and no lower than what it puts out at idle. im sure there is more to this you'll have to find out the specific voltages and ranges of the map sensor being used. ![Very Happy :D](./images/smilies/icon_biggrin.gif)
DRAG SPEC MX3 BEING PARTED OUT.
BUY ALL MY STUFF OR DIE.lol, SERIOUSLY BUY MY STUFF. PLEEEASE
- cjthor
None of you have a dohc right? I am trying to put in my afc and am having a lil trouble. There are two input wires for the maf going to the ecu. I am gonna try and call apexi and see if they can help. These directions suck!!!
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
