Test pipe
- mitmaks
Test pipe
Hey guys, anyone running test pipe instead of their cat, was it easy to install, power gains? legal on road? loud? post some feedback, im looking to install one on my k8
- masonholmes
Re: Test pipe
Of course it's not legal.
There is a bolt-in style going on Ebay right now.. Biggest prob you will probably have with that is if an old bolt snaps or somthing. Your engine will be a little louder/more drone-y/more raspy without a catylitic converter as well.
1993 MX-3 ~ SE * 2.5L Swap'd
1993 RX-7 ~ Rotary Performance Built
1996 MX-5 ~ M-Edition * Topless, Daily Driver
masonholmes@hotmail.com
- masonholmes
Re: Test pipe
Looking at dyno "results" on PTalk, on 2.5L's, I'd say it's not worth messing with unless you're looking for a cheap alternative to replacing a bad cat - and don't mind the difference in noise. (or maybe if you're highly tuned it might be worth it, performance wise)
- SE-Man
Re: Test pipe
Your better off gutting your CAT instead of useing a test pipe, its cheaper and retains the "legal" look, but will not pass emissions.
Re: Test pipe
hollowing out the cat will seriously ruin the airflow...
either run a straight through pipe or a highflow cat...
nope-mx3
nope-mx3
:: 2001 Mazda Mx-5 Sport // 2013 Volvo V40 D2 Momentum ::
Re: Test pipe
i know someone who ran a test pipe through a cat
- SE-Man
Re: Test pipe
I sure hope you didn't think I ment "Keep the hollowed CAT hooked up" do you. You exaust would smell awful, like it was flooded.Originally posted by nope-mx3:
nope-mx3
