How to adjust door alignment?
- jumboplay
Anyone know? My driver's door sags a bit and it almost rubs at the rear bottom. Hopefully this is easy to fix. Any ideas? thanks!
-Tom J, proud MX-3 pilot-
Get your entertainment upgraded at http://www.tommyv2.com
1996 MX-3 RS/GS hybrid, OBDII B6-ZE, painted Mazda crystal white, ZX-2+Eibach, Miglia Spyder 17"s, markerflash, black altezzas, insane fuel economy, too many other mods to list...
Re: How to adjust door alignment?
I've got the same problem. I even had someone lift up on the door all of the way while I tightened the four bolts down, and it still sags a bit. I am going to pull the doors off and drill out the holes a bit more to give me more play. That should take care of it.
My Cardomain site
My Cardomain site
maybe your pin has dropped
Pin has dropped? Not sure what you are talking about. The only pin in the door hinge just prevents the door from opening further than it should.
My Cardomain site
My Cardomain site
I havent ever really looked in my car for a pin but in my friends car his pin had dropped and this had affected the doors ability to close it had to be sort of lifted to be closed
- mitmaks
dude you dont know what youre doing if you didnt **** it up already, DONT, STOP!! you need new bushings, go get them at local parts store or mazda dealer, should be like $2-$5 pull door off take old ones out insert new ones in and install door back on.Originally posted by mx3man83:
