ive got a problem with my mx3 1.8 v6......when warm its idleing very badly and its started to stuuter badly under acceleration.....the problem is getting worse.
ive changed the spark plugs and there was no deposits on the old ones and they seamed ok....anyone have any ideas what it might be before i take it to the garage..
thanks..........paul
poor running
- mitmaks
Re: poor running
check your disty cap, and vacuum system.
Re: poor running
thanks for the reply.....im sending it in to get i full diagnostic check just after christmas so it should hopefully pick up any faults in that....im just hoping it doesnt cost too much..
Re: poor running
hey Paul this is probably to late but I'll give it anyways.
Two possibilities come to mind, spark plug wires or a crack in the plastic ribbing on the intake just before the throttle body.
If not one of these then there are other things but it gets more complicated and more costly.
Andy P. 93 GS P.S. Please let us know what it turns out to be.
Re: poor running
hi....well its had its full diagnostic check today and they are having difficulty showing up any problems....ecu ok......fuel ok....air ok.....they have found (but for some reason not picking up on diagnostic with any type of pattern)a small crack in the rotor arm so they are going to change that and the dizzy cap.
its quite a big crack but there are no burn marks near it....its not missing on one particular cycinder but missing quite randomley which again could point to the crack in the rotor arm...
anyway thats getting changed in the morning...ill let you know how it works out...
