headlight swap
headlight swap
I was looking at various headlights of cars today at work, and I came to this conclusion PT Cruisers, Taurus, and sebring. Have basically the same headlights as the MX, anyone considered any of these for a swap?
93 GS, KLZE, KL31 ECU, Centerforce Stg 3 Clutch, 2.25" Exhaust w/Flowmaster muffler, OBX Headers, Pheno Spacers, Front & rear X-drilled/slotted Rotors, KVR pads, SS brake & clutch lines, Ractive Filter, H&R Springs, Tokico Blue Struts, 8mm Accel Wires, MSD 6A w/ Blaster 2 Coil, HVAC Indiglo Panel. *Sold*
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
Re: headlight swap
YOu may want to look at modifying existing housing to fit theirs, rather than the whole headlight assembly. You will want to make sure that their reflector inside is adjustable, because if you cut your housing you will not be able to alight your lights. On the easier note it is probably just easier to get Hella 90mm projectors in H7 or H9 format and mount them inside your housing. They do come with adjusting screws too. And you can also get them in high or low beam. The cost is about 70 USD I think for each. Alternatively, try to source some H4 Mx-3 lights of J-Spec or E-Spec. I have J-spec H4 and even with the "wrong" flair on the left vs right they are way better than our DOT 9004 lights that mx-3 comes with stock. I use Stock H4 bulbs too. Sometime in the spring I will be selling My H4's, but I am not certain yet. Btw, the baking formula for Mx-3 headlights is 200F preaheat, than bake for 10min. Use owen mitts and table/butter knife to take lenses off. Good luck.
Re: headlight swap
SEE.. another person agrees that the taurus lights will work. I dont know what year taurus it is (its not the newest gen). I believe its the gen prior to that. Anyways i think the PTs are too long and i cant say i've looked at the sebrings.
Shaun Newman
Re: headlight swap
I've seen sebring lights on a crx, it was kind of a dumb conversion, why would you want taurus lights on your car? Originality? It'll be original alright, but it'll also be taurus lights, actually all 3 of those cars' headlights don't look as good as ours do already. ![Wink ;)](./images/smilies/icon_wink.gif)
-Mark Lathrop
1992 MX-3 RS-T
B6T with some goodies
"...I told those fudgepackers I liked Michael Bolton's music..."
1992 MX-3 RS-T
Re: headlight swap
why doesnt anyone come out and try to modify our own headlights, i was thinkin of modifying it and give the internal housing( the reflector section) a black kinda look like some of the VDUBs i have seen around, like this one!
I would be the first to buy if anyone makes these!
![Image](http://www.sikbluemx3.com/sigs_4.jpg)
Re: headlight swap
ive done that already when installing my halos. i did it to the side housing only because it couldve affected the beam of light if i painted the main housing. i think it looks really good.
- team slideways
- team slideways
Re: headlight swap
PT Cruiser lights would look sick as hell on the MX3. Marshmellow, you got any pics of your halo's?
- millionflame
Re: headlight swap
Any lights work. Just some require less work. The Taurus lights are an ok shape, but they don't even have any NICE looking projectors (or reflectors) for that matter.<p>PT lights are neat, but that's about it. They'd be similar to putting in Celica lights because of their angled layout (they are like at 45 degrees as opposed to flat or whatever at the bottom).<p>The easiest thing I could think of NOW, would be either get those damn J-Spec or E-Code lights for our cars, OR mold a fiberglass (like someone mentioned here earlier) pod of our lights and then put some Hella 90mm in them.<p>Good luck.<p>~A
~ Millionflame (94 GS 120K)
- Andrew_Pakula
Re: headlight swap
- mitmaks
Re: headlight swap
i cant believe someone copied my idea already lexus es300headlight conversion!!!!! i am gonna get that dude whoever that is ![Mad :mad:](./images/smilies/icon_mad.gif)
Re: headlight swap
you are correct quinn.
- team slideways
- team slideways
- mitmaks
Re: headlight swap
if u ment these? THOSE arent accord those are lexus es300 '92-96 production years
![Image](http://www.zerokarma.com/mx-3/conversions/accord2.jpg)
