How do u run a wire from the door to the inside of the car...i thought this would be easy but it turned out 2 be a pain in the *** >?
thanks
question
- Dali
Re: question
on the inside of the door and inside the car there are clips that run the wire through the rubber hose. these are almost impossible to remove and they are wire harnesses so you will either drill holes through them or add wires into the harness clips. i had to remove my dash to get to the clips on the inside to remove them and the driver side is way harder then the passenger side to get out. the harness clips on the door and inside are the same shape with one clip on top one on bottom and two on each side so each of the four harness peices has six clips. you cannot just feed a wire through because there is nowhere for it to go.
1993 White gs klze.
Re: question
wow...its gonna be alot harder than i thought then..ok i'll see what i can do..thanks alot
