klze/klde valve train specs
- babyblueMX3
hey guys..I know this could be usefull..Me and skelly on probetalk are completing a full analysis of the ZE heads..I added pics of all the components...this IMO should be stickied or put in the FAQ..here it goes
from skelly:
Okay, here we go. Most measurements are rounded off to the nearest 0.005" because of observed difference between same parts as well as inconsistencies in surface textures resulting in variable readings. I don't have any reference as to OEM specifications, but I expect you'll find these to be pretty darn close except in the case of the inadvertent type-o:
intake - exhaust - measurement
1.705 - 1.830 - valve spring uncompressed height
1.160 - 1.045 - valve spring O.D.
0.800 - 0.750 - valve spring I.D.
0.230 - 0.230 - valve stem dia.
0.175 - 0.175 - valve stem dia. @ clip (jargon?)
1.258 - 1.085 - valve face O.D.
3.745 - 3.745 - valve overall len.
1.110 - 1.000 - spring seat/shim O.D. (jargon?)
0.610 - 0.700 - spring seat/shim I.D.
0.018 - 0.018 - spring seat/shim thickness
0.350 - 0.350 - spring retainer lower I.D. (Note 1)
0.390 - 0.390 - spring retainer upper I.D.
1.113 - 0.985 - spring retainer O.D.
0.320 - 0.335 - spring retainer overall height
1.295 - 1.180 - Lifter O.D.
1.235 - 1.115 - Lifter O.D. @ oiler (Note 2)
1.215 - 1.100 - Lifter I.D.
0.400 - 0.400 - Lifter center pin contact surface O.D.
1.025 - 0.945 - Lifter overall height
Notes:
1. The retainer's I.D. is tapered to use spring pressure to increase pressure on the clips
2. The lifter has a groove in the outer edge. This is the diameter of this recessed groove.
pictures: ZE exhaust on the left and intake on the right
HLA
RETAINERS
VALVE
VALVE SPRINGS
<small>[ November 22, 2004, 12:23 PM: Message edited by: babyblueMX3 ]</small>[/img]
from skelly:
Notes:
HLA
RETAINERS
VALVE
VALVE SPRINGS
RIP 400whp ZE-T MX-3
- babyblueMX3
Re: klze/klde valve train specs
KLDE heads specs:
KLDE Cylinder Head Specifications
Valves
Intake Valves
Face Angle - 45 degrees
Head Diameter - 1.253-1.265 inches
Minimum Margin - .035
Minimum Refinish Length - 3.667
Stem Diameter - .2350-.2356
Exhaust Valves
Head Diameter - 1.081-1.092
Minimum Margin - .039
Minimum Refinish Length - 3.720
Stem Diameter - .2348- .2354
Valve Springs
Intake Side - Free Length -1.729
Exhaust Side - Free Length - 1.847
Out of Square - .064
Pressure - 52-59lbs @ 1.524
Cylinder Head Specs.
Cylinder Head height - 5.252-5.260
Valve Seats - Seat Angle - 45degrees
Seat Width - .031-.055
Valve Guides
Intake Guide I.D. - .2366-.2374
Valve Guide Installed Height - .579-.602
Exhaust Valve
Valve Guide I.D. .2366-.2374
Valve Guide Installed Height - .480-.504
CamShaft Specifications -
Journal Diameter
Left Exhaust Camshaft -
No.1 -1.1801-1.1809
No. 2, 3, &4 - 1.0201-1.0209
No. 5 - 1.0213-1.0220
Left Intake Camshaft -
No. 1 - 1.0213-1.0220
No 2,3,&4- 1.0201-1.0209
Right Exhaust Camshaft
Right Exhaust Camshaft -
No.1 -1.1801-1.1809
Lobe Lift
Intake and Exhaust - 1.7145
Valves
Intake Valves
Exhaust Valves
Valve Springs
Valve Guides
Exhaust Valve
Journal Diameter
No.1 -1.1801-1.1809
No.1 -1.1801-1.1809
Lobe Lift
- babyblueMX3
I took some other measurements today..
ze intake ports:
1.85x1.15
corner seems like a 0.35 radius
ze exhaust ports:
1.65x1.02
corner seems like a 0.50 radius
97 a-spec millenia intake manifold ports:
1.81x1.10 (they seems a LITTLE smaller than the ze head intake ports)
66mm neck(parts that meets the TB)
some k8 measurements..
k8 exhaust manifold ports:
1.81x1.21
downpipe:
1.78ID(part that connects to the exhaust manifold)
1.90ID(part that connects to the cat)
kl01 vaf is 60mm
these measurements would be good infos for someone trying to do a port and polish or portmatch anything
<small>[ November 22, 2004, 04:44 PM: Message edited by: babyblueMX3 ]</small>
ze intake ports:
1.85x1.15
ze exhaust ports:
1.65x1.02
1.81x1.21
downpipe:
kl01 vaf is 60mm
- babyblueMX3
I guess people just don't care about that
Naw, I give you mad props for that!
<small>[ November 24, 2004, 08:17 AM: Message edited by: Nallboy ]</small>
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
make this FAQ good job babyblue
93 Kandy Tangerine Mx3 GS-DE
02 Subaru Impreza OBS
& Lots of Toys to haul
- babyblueMX3
took other measurements today
Last edited by babyblueMX3 on September 28th, 2005, 5:51 pm, edited 1 time in total.
good info to have around...keep up the good work.
Sacramento Raceway, CA
92 Mx3 GS
New Time 13.82 at 101.75 2.205 60ft (RIP beast klze engine)
Updated mods now... KFZE, SS Autochrome Headers and a Sweet a-- 3' Electric Cutout after it, KFZE LSD trans, Millenia manifold, KL36 ecu, Blown motor mounts, custom CAI, Custom ground wire kit, 9mm Plug wires, 2 1/4 exhaust, (Hei and MSD external coil mod), all accessories.
92 Mx3 GS
This is awesome info man. Imma be tearing my motor apart in spring to port/rebuid and this is going to help a lot! Babyblue is going down in MX-3 history!
GS-R SE
Fixin's
- babyblueMX3
thanks..I'll keep up the work
- papa roached
this needs to be FAQed
Are the curved neck ZE motors the same as the millenia or the same as the all other ZE's?
91 Eagle Talon Tsi AWD *RIP*
- babyblueMX3
both have the same heads so I assume they are all the same.. the measurments I took though came from a ms8 ze (straight neck/kl31 cams)
VERY nice, very very good information to have. I'm truely impressed Babyblue!! Good work man! And skelly on PT, isn't he the one who fabricated the MAF coversion for his probe? He is a wizard too!
THIS USER HAS BEEN BANNED, DO NOT DEAL WITH HIM. - MX-3.com Admin
