thats what i think too, it might be stupid to ask but, do you have engine and is it getting to every part of engineOriginally posted by hgallegos915:
dang..that sounds like if you ran your engine without oil..if its metal to metal banging sound. its a warped camshaft.if its that. i ALWAISY check my engine oil everytime i leave.because ive killed 4 cars that way. the engine seizes...u can remove the oil pan and check the bearings..if ones loose..well ur best bet is to rebuild the camshaft is pistons havent beend amamged..or get a new engine..klze it!
car feels like a 3 cylinders !!!!
- mitmaks
Re: car feels like a 3 cylinders !!!!
weird. Friction gears?
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- babyblueMX3
the friction gear spring noise is alternate..not always the same..tick tick tititick tick..Originally posted by Gro Harlem:
I just don't get what you're saying here budOriginally posted by mitmaks:
Nice I'll check this tonight..Got to go to work..I'll keep you guys updated tonight..Originally posted by PATDIESEL:
To check the disty, pull the plugs one at a time and leave them in the head loose from the spark plug. Have someone crank the car, if you hear the ark then the disty is probably ok. HLA's won't do anything to keep the car from running, all they do is lubricate the cam better. If you ran the car out of gas it might take a while to get it to crank. To make sure you are getting gas just pull one of the gas lines from the fuel rail and have someone turn he car over a few times, you'll see the gas come pouring out of the fuel rail or the line which ever you pull. To check the spark plugs pull the plug and install it back in the plug wire then hold it close to the strut mount bolt, have someone crank the car and wathc for arc between the end of the plug and the strut bolt. If all that and the timing checks out you may need a mechanic. You might also run a diagnosis, I don't remember exactly how to get the CEL to flash for codes, but I'm sure a search will find the info.
Good luck
Thanks a lot so far guys..I wish it's one of the problem above...if not I'll have to crack down the heads
RIP 400whp ZE-T MX-3
- bmwm3guy
Maybe thats what you meant... and how is he supposed to check that?Originally posted by mitmaks:
do you have engine OIL and is it getting to every part of engine
<small>[ September 19, 2004, 08:42 AM: Message edited by: bmwm3guy ]</small>
I think the culprit is the fuel lines
"A hero and a coward both feel fear but it is the hero who reacts first while the coward hides behind the hero"
- babyblueMX3
you think so ? somebody else told me that my fuel filter maybe clogged...
BTW i doubt it's the fuel pump since it's a almost new walbro 255 HP FP
- bmwm3guy
could be the Fuel pressure regulator as well. Injectors maybe?
- babyblueMX3
I doubt the injectors but maybe the FPR
maybe the pump is too much for the oem fpr and it has gave up ?
Or when you ran your tank down to nothing you sucked up some sludgy fuel from the bottom of the tank and clogged up 3 of yout injectors or something.
Mods:
- ZE, Mike seli 214 intake cams, Ported n polished heads, Interprep valve springs, DE retainers, rebuilt bottom end, toga main and rod bearings, toga hv oil pump, CZT 67mm tb, mbx udp, ported intake mani, SS headers, 2.5inch full exhaust, racingbeat muffler, highflow cat, megasquirt v2.
new toy, 86 TII rx7, JDM S5 motor/turbo, + alot of other goodies
- babyblueMX3
well the fuel filter would have cought it right ? I meanm, it has to pass the one in the fuel tank and the one in the engine bay..what are the chances ??
- bmwm3guy
slim-to-none... Quite possible that the Walbro is too much for you filter, or the FPR.
- babyblueMX3
ok well I have tons of things to check when I'll come home...at least I have somewhere to start
- babyblueMX3
ok update:
spark is good
lots of fuel
plugs are black (probably from running rich).
I took off the intake manifold, and valve covers...everything looks good..Now I'm in the processus of checking the timing..I removed all the belts (accesories), crankshaft pulley tensioner etc...I remove the right part of the timing belt cover..I just need to remove the left one and check the timing...
so anybody else got an idea ??????????
spark is good
lots of fuel
if your hlas are gone do not run the motor you will ruin the cams and will have to have them to be replaced or resurfaced. have you checked the compression of each cylander?
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
maybe you didnt burnt a couple of valves?
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
