PROBE GT CLUTCH SAME AS B2200 CLUTCH
MAZDABLOOD
I WOULD HAVE NEVER BELIEVED IT UNTIL I SAW FOR MYSELF.MY BUDDY WORKS FOR AUTOZONE AND HE TOLD ME THAT THE B2200 CLUTCH IS THE SAME.I THOUGHT BULL**** UNTIL I CAME HOME AND WENT ONE AUTOZONE .COM AND FOUND OUT THAT IT IS TRUE.SO THAT MEANS THAT WE BUY A PROBE GT CLUTCH AND ITS THE SAME AS A B2200 THAT'S WEIRD!!!!!
lakersfan1
Re: PROBE GT CLUTCH SAME AS B2200 CLUTCH
What year B2200? And this is for our V6? Because I see B2200 cross references with 88-92 626, but nothing about 93+ V6's.
Yup B2200 is F2. First gen MX6. It is also the same as 2nd gen Rx7's, believe it or not. Not compatible with MX3's though.
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
MAZDABLOOD
got to autozone.com and search for clutch for a 94 probe gt and a 89 b2200,and you'll see that they are the same part #
lakersfan1
By George, they are.
Valucraft part #NU31218 for the clutch kit.
- papa roached
the big queston, does this info really matter
Gro Harlem
no
DONATE TO MX-3.COM
DONATE TO MX-3.COM
