Buying probe motor
Buying probe motor
hey i can get a probe gt that was wrecked in the back when it still ran perfect. the guy told me he would give it to me for $300. is there any reason for me not to get it if i plan to do a full rebuild. how much power can i get out of the probe engine?
Counting Bodies Like Sheep to the Rhythm of the War Drum
- mitmaks
Re: Buying probe motor
what year is it, can you get some pics
not sure what year, its the last gen though, 2.5v6
what is the engine code on that motor
You can get as much power of of a KLDE as a KLZE. New intake cams and Millenia intake manifold with phenolic spacers should put you right there.
woah..this engine fits out cars??
-hec
- babyblueMX3
![Confused2 :confused2:](./images/smilies/confused2.gif)
RIP 400whp ZE-T MX-3
I wouldnt go that far. The ZE still has bigger ports in the head and 10:1 compression.Originally posted by lakersfan1:
91 Eagle Talon Tsi AWD *RIP*
- mitmaks
dude grab it, you getting whole engine and wrecked car right? swap engine and part out rest of car, thats a deal dude, even for just engine $300 is pretty good
im going to do a full rebuild with cams, pistons, port polish, basicly everything i can
Yes, it does. But a heavily modded KLDE can get to stock KLZE levels still. Now if you did the same mods to a KLZE as a KLDE, the KLZE would definitely make more power. Just saying 200 HP at the crank is doable on the lesser engine.Originally posted by TsiMiata:
