I have changed my water pump and a few hoses. My temperature gauges seems to level out at about 60% up the gauge. I can't remeber if that is hotter than before.
Where does your temp gauge line up when the car is at running temperature?
Thanks, Mike
Temp Gauge Level
Re: Temp Gauge Level
mines the same about 60%.... seems a bit hot but i guess it likes it that way.
Mine sits right in the middle. I'm not sure on the MX-3 but mazda changed the way the temp gauge works on most of their cars in the mid 90's. Instead of being an actual temp. gauge it really only indicates three positions-
cold- gauge reads below C
warm- Gauge reads in the middle
overheated- gauge goes to H
My 93 has a temp gauge that actually indicates the real temperature. I do know that 93+ RX-7's & 94+ miatas have the fake gauge. It is possible that when mazda dropped the third sensor in the water neck it may have switched the MX-3 to the fake gauge. So what your gauge reads on a 94+ MX-3 may not be anywhere near the actual temperature of the engine.
91 Eagle Talon Tsi AWD *RIP*
